Home pageTrainingTraining ResourcesChargesWeb ResourcesGeneral Info
Weight limits - if you want to come along for a trial flight with us you must weigh no more than 15.5 stone / 98kg fully clothed.  If you wish to undertake a training course with us you must weigh no more than 15 stone / 95kg fully clothed.  If you less than 60kg / 9.5 stone then please let us know before you book with us.
Clothing - We supply flying suits, helmets, headsets and gloves for your flight.  You will need to wear clothing suitable for being outdoors at the time of year for your flight.  Close-fitting clothing is best, anything loose or baggy can get  uncomfortable under a flying suit.  Scarves or anything which trails after you are a definite no-no.  Depending on the weather It's worth bringing an extra layer or two with you.  Flat-soled shoes which allow ankle movement are best - trainers are ideal, walking boots are not.
Location - Wickenby airfield is to the East of Lincoln.  Click here for a map showing our location.  The address is The Old Control Tower, Wickenby Aerodrome, Langworth, LINCOLN. LN3 5AX.
Facilities - Wickenby airfield has a bar / cafe with lounge area plus an outdoor seating / viewing area.  There is ample parking.
